New member with elec. problem
Hi to everyone
I have a 99 b1500 van with a 5.9. I bought this van cheap being that the last owner had hit a deer. Replaced all damaged parts. Bumper, grill, headlight, and brackets. This van is a conversion van with 90k in it. Have had numerous elec. problems. Have replaced pcm twice ( First rebuilt failed tranny wise) Now have replaced TPS, MAP, and crank sensors. Have checked as many grounds as possible. Most prooblems fixed now but sometimes it wont start and dont here fuel pump. I leave key on, unplug and replug in the fuel pump relay and it fires right up. This thing has drove me to drinking and i dont drink. Any help would be appreciated. Also I am a disabiled vet.
Welcome to DF
Check the pin connections at the PCM. Make sure all the wires are locked into position. If the are not, it will cause a no start or other codes that you are having.
Thanks for answering. I have finally traced this damn thing to were #c19 pin in pcm is not grounding the fuel pump relay as it should. This is the third rebuilt pcm I have put in Im starting to wonder about there work does anone know any other problem why it won't ground. And I have checked the wire from plug to relay ane its fine. ???????????????????
I have been having a similar issue, runs fine then bam wont power up the pump, I saw a 4x4 post from 2006 where the guy bypassed a wire from the relay back, is this common? My problem is a dreaded intermittent issue!
Trending Topics
Ive been tracing mine. The wire coming out of the pcm is c19 This wire is supposed to ground the relay to activate. From what i can tell it have to be a ground problem with the pcm or the pcm itself
