P0306 code
Old Dec 6, 2016 | 04:08 PM
j404ski's Avatar
j404ski
Default P0306 code
I have a 2001 dodge 5.9L in a motor home and it keeps giving me a 306 code, misfire in cylinder # 6. I tried changing the spark plug, wire, and fuel injector and gasket for throttle body. I cleaned the IAC valve and air cleaner to no avail. Any idea on what it may be? Thanks for any help you can give me.
Old Dec 7, 2016 | 09:12 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
Do a compression test on it and let us know what you get for PSI.
Old Dec 8, 2016 | 09:49 PM
funair02's Avatar
funair02
I had a similar issue and I had a burnt valve and a cracked head
Old Dec 9, 2016 | 04:08 PM
j404ski's Avatar
j404ski
what test did you do to determine that?
Old Dec 10, 2016 | 11:45 AM
funair02's Avatar
funair02
What alloro said
and this:
Old Dec 13, 2016 | 09:24 PM
j404ski's Avatar
j404ski
Too cold to do that now so it'll have to wait.
Old Dec 15, 2016 | 11:46 AM
blackvan's Avatar
blackvan
Replace distributer cap and rotor, buy the best you can get. Contacts must be brass not aluminum. You'll never get more than 3, maybe 3.5 years out of a cap/rotor set on these engines before they start to misfire.
If it is still misfiring with a known good cap/rotor it is either spark plug wires or spark plugs. Brand matters: I recommend either NGK (factory equipment) or Autolite, depending on your preference.
The 5.9L heads aren't likely to crack, though anything is possible.
Old Dec 16, 2016 | 02:41 PM
j404ski's Avatar
j404ski
Did all that and cleaned/swapped fuel injector with #7 cylinder. Got a nice steady 23 inches of vacuum, seams to idle smoother. Will take it on a run after the weather warms up. Thanks for the suggestions.
Old Jan 4, 2017 | 08:52 AM
blackvan's Avatar
blackvan
Glad you got it sorted out
Old Jan 5, 2017 | 05:03 PM
j404ski's Avatar
j404ski
Had it out a couple times, running good so far.
