no oil psi on gauge
Old Jul 24, 2018 | 09:18 PM
lex Luthar's Avatar
lex Luthar
Default no oil psi on gauge
2002 ram 1500 van 5.2 V8 replaced the sender and still no psi on the gauge " check gauges light on " checked with a real gauge and have 45 psi . it started out of the blue just 1 morning .
Old Jul 25, 2018 | 08:13 AM
See if you are getting power to the sensor. (key on, engine off should work just fine.)
Old Jul 25, 2018 | 08:34 AM
HemiLonestar's Avatar
HemiLonestar
You might post or ask the mods to move your question here: https://dodgeforum.com/forum/dodge-ram-van-100/ where it will get better visibility and/or better answers.
Old Jul 28, 2018 | 02:57 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
With the key on, touch the sender wire to ground and see if the oil gauge pins. If it doesn't your gauge could be fried.
