Dodge ram B350 VAN. suddenly died, will not start back up. PLEASE READ ALL INFO
Old Sep 12, 2018 | 09:24 AM
  #21
Got wiring diagrams? You lost power somewhere...... likely under the hood. (yeah, that's gonna be fun.) I suspect there is more than one main feed to the ignition switch, and one of them is not getting power.
Old Sep 12, 2018 | 10:08 PM
  #22
Brando224's Avatar
Brando224
I cant seem to find any diagram for this. online or at a store. its a 1993 dodge ram B350 van.
Old Sep 13, 2018 | 08:11 AM
  #23
Check here. There is some hoop jumping involved to get access, but, it's free.
Two wires provide power to the ignition switch, a red one, and pink w/black trace. Both are protected by fusible links. Verify you have power at both. (my guess would be: "No".....)
Old Sep 13, 2018 | 08:43 PM
  #24
Brando224's Avatar
Brando224
that website is not secure. vunurable to hacks, so i made a fake email. still didn't work. bad website i think.
Old Sep 13, 2018 | 09:14 PM
  #25
SteveR's Avatar
SteveR
I have used that website in the past and it works well. No account is necessary, just pick through the drop-down menus and go. The files it sends you are PDFs even if they don't say so...force Adobe to open them or rename them to something.pdf in order to open them.
Go through your grounds and also look at the big +ve connectors. One is likely adjacent to your battery and another is buried in the loom against your firewall. If you have aftermarket battery terminals that is also a likely culprit. Do not replace any more parts until you determine where the break in the power supply/return is.
Old Sep 15, 2018 | 01:30 PM
  #26
Brando224's Avatar
Brando224
Found the problem and fixed it! i actually slept like a king last night haha.
So! it was the red wire on the ignition (found on the bottom part of steering wheel)
it leads from ignition through a felt wrapped casing, inside of a taped up cluster going from the bottom of the steering wheel towards the upper left part of the brake pedal.
which is plugged into a cluster plug about the size of the palm of your hand, that leads you through the firewall. which leads to more taped up clusters.
so the power wire to ignition actually sits in the cluster that is placed further behind the brake booster. ( there are 2 clusters placed snug on top of brake booster)
although all fusible links were exposed, i couldn't see the wires true color due to some fading and dirt. so once inside of the cluster i found the ignition power, which led to a fusible link, and on the opposite end of the link there were both an orange wire and white wire. surprisingly the Break wasn't at the tip, but it was actually 4 inches away going into the next link! not even sure how i'm going to put a shrink tube around it. but yea. that's how i solved my issue. i seen a lot of these issues going on, on the website here. so i wrote a more detailed explanation of my Problem plus solving, hopefully to save someone else from a disastrous headache.
Old Oct 2, 2018 | 05:45 PM
  #27
Brando224's Avatar
Brando224
well now I’m having a bigger problem. I fixed the fusible link. But now somewhere down the line one of the wires ( in this case, it’s a blue wire ) it has melted this blue wire inside the same cluster... I can’t find a short, and I even installed a brand new harness. And when I go to start the van it will turn like it’s going to start but it never starts... but instead it is smoking my wire harness where that same fusible link was ( the red one that led to the 2 wires, orange wire and white wire. Now the orange wire is a fusible link, and somehow is is getting too much power I guess, so it has burnt through the rubber insulation around it. I also noticed a blue wire ( totally separate from the problem I had before... ) does this mean somewhere down the line that the blue wire has touched my ignition feed? Which is causing my orange fusible link to burn? As well as the blue one? I can’t make sense of any of this.
Old Oct 7, 2018 | 08:44 PM
  #28
jumper.cables's Avatar
jumper.cables
Does anyone know where I can find a wiring diagram for a 1984 Ram Van B350? The site above only goes back to 1986. Thanks.
