97 B3500 Extended Heavy Towing
![Exclamation](https://dodgeforum.com/forum/images/icons/icon4.gif)
Hey guys,
This might be a stupid question. I'm out on a road trip in my 97 B3500, which just so happens to be a rather heavy class B RV - right under 9,000 pounds. I just found a vehicle I'd rather like to buy, and I'm wondering if I can tow it home. My GVWR is 13,500, the vehicle I'm looking at weighs right around 5,000. So even without a tow dolly or a trailer that puts me 500 pounds over the GVWR. Is this likely to be an issue? How far can I push it?
Van has 175k miles, new trans with less than 5k, new brake system at the same time (literally everything but the pedal), new radiator. 5.9 V8. It'd be approximately a 2,000 mile drive home.
Hey guys,
Did you check your tow hitch rating as well? Mine is only rated at 4000 pounds. I personally wouldn't do it with my van as I know it would struggle. The short wheel base of the van will also make it a white knuckle drive. I'm sure the tail will be wagging the dog. Good luck in whatever you decide.
