2002 ram 1500 van 5.2 v8
If you want to be sure, the numbers to look up are on a plate right behind the lower transmission line in your picture it'll be like "pk" and half dozen numbers and letters after that... Also, my original van transmission had a sticker on e top that you could see with the doghouse removed... they're the same numbers...
I put a 2000 46RE in my 2003...but I swapped the wiring harnesses, the PCM, the TCM and upgraded to a v8.
I did have an weird issues...I am unsure why this happened (i think the tranny I got was rebuilt) because there are two temp sensors for a 2000 transmission.
I had the wrong one so overdrive would never work. I had to take it to a tranny shop to figure this out...but yea...swapped the sensor with the right one and now OD with lockup works great!
Trending Topics
