Torque specs for rear differential cover plate?
Old Mar 22, 2020 | 12:32 PM
peppster66's Avatar
peppster66
Default Torque specs for rear differential cover plate?
Hi, I just want to replace the old oil in my rear differential , but I can’t seem to find the proper torque specs for the 12 bolts holding on the rear cover plate, if anyone knows, please let me know,,,thanks,,,,
Old Mar 22, 2020 | 04:41 PM
ElkCon's Avatar
ElkCon
The FSM states 30ft/lbs.
Old Mar 22, 2020 | 04:42 PM
peppster66's Avatar
peppster66
Thank you,,,,
Old Mar 22, 2020 | 08:00 PM
nibroc's Avatar
nibroc
that seems a little much to me
Old Mar 22, 2020 | 08:26 PM
ElkCon's Avatar
ElkCon
you made me get the book out, again lol
Old Mar 23, 2020 | 06:06 AM
peppster66's Avatar
peppster66
That’s interesting, your book tells us to fill to the bottom of the fill hole, and my book said to fill up to 1/2” below the fill hole, so should I just fill it to the fill hole?, I’m just worried about over filling, I read online that I could blow some seals if I overfill, let me know what you do,,,thanks,,,,
Old Mar 23, 2020 | 08:10 AM
So long as the vent tube is clear, no danger of blowing seals.
Old Mar 23, 2020 | 10:29 PM
ElkCon's Avatar
ElkCon
Yep...I learned all about the vent tube when I drove through two feet of water...lol
Old Mar 24, 2020 | 08:23 AM
I usually route all my vent tubes up under the hood somewhere. (yes, even the rear axle) But, I take my truck into some odd and strange places too...... Hose is cheap, axles are not. I have seen too many destroyed by folks going thru water that is 'too deep'.... submerging the axle cools it, (and the air inside it.....) so it develops a bit of a suction in there, if the vent tube is submerged..... it sucks in water. Carnage follows shortly thereafter.
Unfortunately, dodge, in their infinite wisdom.... put the vent for the auto trans at the top of the pump, inside the bellhousing..... I would like to thump the idiot that thought that was a good idea.
Old Mar 24, 2020 | 01:56 PM
peppster66's Avatar
peppster66
Thanks for all your info,, I learn so much here,,,,I went under today and checked the vent and hose , they are both clean and clear,,I was expecting to see a check valve on the end of the hose, but there was nothing,,,there is no mention of a valve in my repair manual, so I was wondering if our vans just weren’t equipped with a check valve, or someone has removed it,,,let me know if you have one,,,thanks,,,
