1995 b2500 conv van
Old Apr 21, 2021 | 09:43 AM
Larry Allison Brockway's Avatar
Default 1995 b2500 conv van
1995 b2500 conversion , any help would be appreciated . replaced the ecm a few times only to have now the fuel pump voltage drop out and no pump ??
Old Apr 21, 2021 | 09:55 AM
Why was the ECM replaced?
Does the pump prime? Will the engine run at all?
Old Apr 22, 2021 | 10:04 AM
the engine would start and running then die ,then start then die ... got a reman ecm and drove it a couple days (ie) 200 miles . return the reman purchase a another and this gremlin showed up . sent in the veh ID # on original ecm because they said it had to match for camper conv . , now when i turn on the key to start the engine initially the pump comes on and stops and voltage drops out , wont run fuel pressure wont build . >? some ive asked say the ground is insufficient but not having wiring diagram i can not figure out which is the ground . or even understand why this is happening . should have been a plug and play ecm .
Old Apr 22, 2021 | 10:14 AM
See if you can find wiring diagrams here. Check your ground.....
