dodge van ram V6 problem the vehicle stalls while driving
Old Apr 26, 2021 | 04:09 AM
laurent perigault 64's Avatar
Question dodge van ram V6 problem the vehicle stalls while driving
hi guys,
I have a recurring problem with my car:
dodge van ram 1500 V6 3.9L Gas years: 1998
my van stalls randomly after start engine ...
and sometimes I do not restart I have to wait several minutes, there is no error code and several parts have been changed such as: radiator, ECM, spark plug, ignition head, panel fuse and pomp gas checked,
Someone would have a little idea or know about this problem
sorry for my english
thanks
Old Apr 26, 2021 | 03:28 PM
Jwilliams41's Avatar
Jwilliams41
Any codes?
Old Apr 26, 2021 | 06:10 PM
Possibly cam or crank sensor. I would lean more toward the crank sensor. Mopar sensor only please, these engines don't like aftermarket sensors.
Old Apr 27, 2021 | 09:33 AM
no,
any error code
Old Apr 27, 2021 | 09:36 AM
hum !!!
ok
i will check
thanks
Old Apr 27, 2021 | 10:51 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
I had this same issue and a new crankshaft position sensor solved it. Other less likely possibilities are the ASD relay, a failing fuel pump, or a failing PCM.
Old Apr 27, 2021 | 03:13 PM
checked , no problem on this way
Old May 6, 2021 | 04:09 PM
1990B150318's Avatar
1990B150318
Alternator?
Is it hard to restart when warm, cold, or always?
Old May 7, 2021 | 05:15 AM
ol' grouch's Avatar
ol' grouch
A failed crank or cam sensor just won't send a signal so the computer doesn't know there's a problem. I'll bet it mostly fails as the engine warms up. Classic heat soak problem.
Old May 7, 2021 | 12:37 PM
1990B150318
Are you sure? There is a code for each.
By example, if the crank position is unknown, that will throw a code P0320 (11)
