Front Drums
Old Jan 30, 2022 | 05:42 AM
Engracia, Grace's Avatar
Engracia, Grace
Post Front Drums
Hi, I am Grace, from Spain and i have a Dodge Ram B350 1992 5.9l V8, and i having a problem finding the front drums for my van. I am wondering if anybody here you help me to find them.
I have purchased already a set of front drums but they are not for my vehicle. I have attached the part i arready bought and now I am trying to find the Drums I need to buy for the van.
if anybody here have any kind of information which could help me to find the drum I need I really appreciate!
Thank you very much and have a good day!
Old Jan 30, 2022 | 07:05 AM
ol' grouch's Avatar
ol' grouch
You have a conversion van don't you? This is a standard van modified for either camping, long distance comfortable travel or other similar use. Most of the rotors (you're looking for rotors not drums) are for the front axle as it came from the factory. These have the shallower off set on the spindle. I did find this;
https://www.ebay.com/itm/39258595827...QAAOSwUf1hs4KM
and this
https://www.ebay.com/itm/16475794121...Cclp%3A2047675
They look like what you're needing. I suspect the conversion company swapped out parts on the front end for heavier duty use. I'm wondering if the front spindles aren't for a dual wheel set up. Contact the vendors to make sure, but both look like the center is much thicker than the B250 parts you were sent.
Old Jan 30, 2022 | 07:11 AM
Engracia, Grace
thank you very much for the info! I really appreciate!
Old Jan 30, 2022 | 09:55 AM
I don't think those are correct. Or the ones linked by the grouch. It appears to me that your rotors have the hub incorporated into them, so, rebuildable bearings. I can find rotors for the 3600 lb front axle, or the 4000 lb front axle, but, not for the 3100 lb axle. Which strikes me as kinda odd. But, I think you are looking for something more like
this this
Old Jan 30, 2022 | 11:13 AM
ol' grouch's Avatar
ol' grouch
I don't think those are correct. Or the ones linked by the grouch. It appears to me that your rotors have the hub incorporated into them, so, rebuildable bearings. I can find rotors for the 3600 lb front axle, or the 4000 lb front axle, but, not for the 3100 lb axle. Which strikes me as kinda odd. But, I think you are looking for something more like this.
Now that you mention it, they do look like a single assembly. I looked on Ebay and they run a bit more there so if the original poster isn't against Amazon, that would be the way to go.
<<No creo que esas son correctas. O los que están vinculados por el gruñón. Me parece que sus rotores tienen el concentrador incorporado en ellos, por lo que, reconstruibles rodamientos. Puedo encontrar rotores para el eje delantero de 3600 lb o el eje delantero de 4000 lb, pero, no para el eje de 3100 lb. Lo que me parece un poco extraño. Pero, creo que estás buscando algo más como esto.>>
Ahora que lo mencionas, se ven como una sola montaje. Miré a eBay y corrí un poco más allí, así que si el cartel original no está en contra de Amazon, ese sería el camino a seguir.
Old Jan 31, 2022 | 10:33 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
You could look on eBay or Amazon for RAYBESTOS 76920R which is your front rotor, or you can get it from Rockauto which is based in the USA but does ship internationally.
https://www.rockauto.com/en/catalog/...hub,rotor,1896
Old Jan 31, 2022 | 10:50 AM
Engracia, Grace
Thank you so much! I will do so! these is great to get the right ones! Once again thanks
Old Jan 31, 2022 | 10:51 AM
Engracia, Grace
Thank you for your help, I really appreciate!
Engracia, Grace
Thank you for your help! I really appreciate!
Old Jan 31, 2022 | 03:49 PM
ol' grouch's Avatar
ol' grouch
Be sure to post some pictures of your truck so we can see it. We're a bit strange that way.
Asegúrese de publicar algunas fotos de su camión para que podamos verla. Somos un poco extraños de esa manera.
