Transmission oil leak
Old May 23, 2022 | 02:15 PM
/Nate/'s Avatar
/Nate/
Default Transmission oil leak
Hi all, new to the forum but not new to my 1995 b3500. This is my second of the same model and year so I am fairly familiar with things. Recently I sprung a tranny leak that is so bad that I have a thick film of tranny fluid on the back van windows after going on the highway!
I might have a leak coming from the bell housing so I'm assuming a front tranny seal there
I also plan on changing out the lines and pan gasket
What Im having trouble finding is a part on the drivers side of transmission, I think it may be leaking where its attached to the transmission. I also think its dripping on the exhaust and eliminating my ability to find a puddle. This is reinforced by the awful burning tranny oil smell every time I park. Photo of the part should be attached.
Can anybody provide insight on what the part is, where to buy tranny lines, or common tranny leaks at 120xxx mile?
EDIT: 5.2 L, 46rh
Thank you
Nate
Old May 23, 2022 | 02:34 PM
That's the starter motor.
You likely won't find pre-bent trans lines.... some aftermarket shops might offer them, but, a quick search doesn't turn up anything......
Are you sure it is trans fluid?? Fluid generally won't move forward from where it is leaking from.....
Old May 23, 2022 | 07:58 PM
Busted Nuckles's Avatar
Busted Nuckles
My thoughts too. Looks like motor oil from rear seal but I'm just guessing. Why change the transmission lines? Clean them up and make sure they aren't rubbing through somewhere.
