Fuel pressure issues Plus some more
Good morning. So what I’m looking at is no fuel pressure at the Fuel rail. I have checked my relay I have checked the wiring is best as I could, and I’ve also replaced the fuel pump again just last night. Now I’m still not getting pressure at the fuel rail. When connecting positive lead of multimeter to positive battery terminal and negative lead on the positive wire at the pump I do get battery voltage, but I don’t believe I’m getting voltage when I just go just check it at the pump. Intermittent problem and it seems like it’s more not running that it runs now and here’s another thing, I plugged in my reader to the OBD2 port and its getting no power, so there’s something up with that and then wondering if that’s connected to it somehow I don’t know if someone please help me I would really really appreciate it. I’m ready to go berserk. Thank you in Advance I really do appreciate it.
In addition, I just replaced the pump again, the first one I replaced in April.... for some reason the lock ring seems to not want to go on... last time I simply greased the threads and it went on fine, this time not so.... I don't have the special tool and can't get one of the loaner tools from the auto parts store... any tips?
thank you very much
When you turn the key to start the vehicle the asd and fuel pump relays engage, The fuel pump will only stay on enough to prime the system. After the engine starts the pcm will keep the relay on. The asd will stay engaged for a while but will shut off if the key is on with the engine not running. Pump needs to prime the system, Have you tried to swap the relays? Fuses may look good but still may have a connection issue(corrosion). You can manually jump the relay to see if the pump runs.
