318 ci timing chain replacement
Old Jul 2, 2022 | 04:45 PM
rebour's Avatar
rebour
Default 318 ci timing chain replacement
I just replace the timing chain on my 1988 Dodge B250 camper. The original chain and pulleys where at 12 o'clock on the cam and 12 o'clock at the crank , I installed the new chain and pulleys the same way and the distributor rotor pointing at no 1 post ( no 1 piston ) and the motor runs perfectly. Can I continue to drive the van without any problem ?
Old Jul 3, 2022 | 10:05 AM
Yep. When the cam dot is at 6, and the crank dot is at 12, number 6 is in firing position. So, you did it right.
Old Jul 3, 2022 | 11:00 AM
ol' grouch's Avatar
ol' grouch
Yep, you did it right. Just keep an eye out for oil leaks for a while, especially if you didn't drop the oil pan. After a couple of weeks of driving, if you don't have a leak, you're done.
Old Jul 3, 2022 | 12:25 PM
rebour's Avatar
rebour
Thanks for your reply,, but I place the cam pulley at 12 o'clock, not 6 . Thats the reason for my quetion posted.
Old Jul 3, 2022 | 01:24 PM
If you hadn't done it right, the engine simply wouldn't run.
Old Jul 3, 2022 | 06:03 PM
ol' grouch's Avatar
ol' grouch
You're fine. If no oil is leaking, and it's running good. Unless it starts to overheat after long drives, there's nothing to worry about. If it overheats a bit, tweak the timing on the distributor. As it is, you did good.
Old Jul 9, 2022 | 05:23 PM
rebour's Avatar
rebour
Thanks to all of you . My Dodge is running good, no leak, no overheating. Your precious advices helped me greatly to sleep well !
