1995 Ram van B2500 transmission compatibility
Old Sep 22, 2022 | 11:03 AM
Anton Tkabladze's Avatar
Anton Tkabladze
Default 1995 Ram van B2500 transmission compatibility
Hi everybody!
My lovely 1995 b2500 eventually stopped on a highway having transmission issues. It doesnt move at all, transmission fluid is leveled, grey and smells burnt. Transmission also is making whining noise so I assume I need a replacement.
New or rebuilt is prohibitively expensive so my only option is a junkyard transmission.
Hence the question: What is comparable transmission I can use?
I believe I have 36rh 3 speed. There is a V6 1996 Ram Van on a yard - will it fit?(google says irs 32RH in it). Also there are plenty of Dakotas and pick up trucks - can those transmission be used in a van?
I googled several hours yesterday evening but i cannot find any info abour wagons
Old Sep 22, 2022 | 12:01 PM
A 95 with a three speed?? Hhhhmmm...... I thought they all had the overdrive trans.... Well, not like I haven't been wrong before.
Any 36RH 95 and older should work. Doesn't matter what it comes out of. Bear in mind though, trans out of a 4x4 will NOT work.
Old Sep 22, 2022 | 12:28 PM
Anton Tkabladze
yep. With 5.2
Is there any difference between 32 and 36?
Also i couldn fid any information about 3 speed on Dakotas
Old Sep 23, 2022 | 07:40 AM
alloro's Avatar
alloro
Van & CUV Section Moderator
All V6 engines have a 3 speed tranny along with an occasional although more rare V8 setup. The OD was probably too much gear for the V6 to handle.
Old Sep 23, 2022 | 02:45 PM
Originally Posted by Anton Tkabladze
yep. With 5.2
The 36 will take more power, and survive. With the 5.2, I think that's what *should* be in there, and definitely what I would be looking for.
Old Sep 25, 2022 | 11:06 AM
Anton Tkabladze
Id be happy to get one. The problem is I dont know where to look for it)
Old Sep 25, 2022 | 11:27 AM
Junk Yard? Have a trans shop rebuild yours? Or, if you have someplace to work on it, rebuild it yourself?
Old Sep 25, 2022 | 10:31 PM
Anton Tkabladze
Junkyars is my only option, van doest worth to rebuild or buy new transmission
Hence the question - there are few Vans on local yards, but v6 with RH32 - will it work instead RH36
Old Sep 26, 2022 | 10:10 AM
alloro's Avatar
alloro
I looked on car-part.com and found several V8 3sp trannies setups. You might have to drive 100 miles to go get it, but at least it will bolt right up.
https://www.car-part.com/cgi-bin/sea...erPage=1&iKey=
