96 ram van maxi gear ratio??
Can't really read much there.... but, my vision ain't the best in any event.
Try running your VIN here. It says 98 and up, but, it has worked for older vehicles as well. That will get you a build sheet, and tell you everything your van came with from the factory, including rear gear ratio. Keep in mind, it's case-sensitive, so, letters should be caps.
