Power Locks Fuse Number
Old Jan 27, 2023 | 12:25 PM
sathington's Avatar
sathington
Default Power Locks Fuse Number
I have a 2001 Dodge Ram Van 1500, I am not near my van at the moment but I need the fuse number for the power locks because my friend who is tending to my van while im away needs to pull the fuse for me (they are not mechanically inclined). Thanks!
Old Jan 27, 2023 | 06:28 PM
Not a fuse, it's a circuit breaker. Little silver box in the in-cab fuse block somewhere.
What are the locks doing that they need to be disabled?
Old Jan 28, 2023 | 03:22 PM
sathington's Avatar
sathington
It’s a yellow fuse on the inside fuse panel, I pull it all the time. I just need to know the number. Could someone help me out or send a photo of the inside fuse panel cover that has the layout of the fuses? Thanks.
Old Jan 28, 2023 | 04:30 PM
From everything I am seeing, it's circuit breaker one. Is the fuse block in the side of the dash on a van??
Old Jan 29, 2023 | 03:13 PM
sathington's Avatar
sathington
It is one of these ones in the fuse box on the side of the dash. If you look at the inside of the plastic cover, the fuses are numbered, one should say "power lock" or something to that effect.
Old Jan 29, 2023 | 03:29 PM
sathington's Avatar
sathington
I think it might be fuse #15, can anyone verify that for me? Thank you.
Old Jan 29, 2023 | 03:47 PM
OK, that doesn't look anything like the images I was finding.....
Found one, yep, fuse 15, should be 20 amp.
Old Jan 29, 2023 | 05:02 PM
sathington's Avatar
sathington
Thanks!
