94 to 97 drivers side wheel well slash guard
I need the above mentioned splash guard on my 96 b van. Every one I check out at pick and pulls is also missing. Is this a real common thing that they fall off and most all of the vans are missing that part? Just to clarify I'm talking about the rubber piece that is held in with plastic push pins that sits behind the wheel and keeps water and such from splashing onto the engine. I was going to check and see if the older vans had the same part, but the ones I checked were gone too.
The following users liked this post:
Overland One (04-05-2023)
My passenger side one is missing on my 1998 B1500 conversion van as are the push pins. There is a new upper control arm in there and I suspect you are are right that someone removed it as it was in the way and just "forgot" to replace it. I am probably just going to drill an extra hole next to each push pin hole and secure some cut up rubber piece in there with zip ties. Easy to install and removal is easy as I can just cut them. I never had much luck with those push pins, especially if they are aged. Even using a removal tool just seems to snap them off.
