1998 B1500, dome lights not working when opening drivers door. They all work when I open the passenger side doors and rear door. I am thinking door jamb switch but I can't locate one on the front door jambs. Where are they located? My van is a conversion van, if that makes any difference
I looked in my 1998 Dodge van factory shop manual and it does not show it as part of the door latch, nor shows locations of the front door jamb switches.I can look again in the morning to see if I can find them
So, will need a replacement latch? I looked on ebay I did not find any aftermarket front door latches. Guess I will have to look in salvage yards for one
Maybe I can luck out, and have a loose/broken wire
Before you go that route, you'd probably want to unplug your existing one and test the wires to see if they activate the domelight. And maybe you'll find the problem while you're in there.
