Brakes suddenly pull to left
Old Feb 15, 2024 | 09:31 AM
  #61
Originally Posted by 1996 B2500
I jacked up each rear wheel and spun the tire, and sure enough, the shoes aren't even touching the drums, I thought I had adjusted them but apparently I forgot to (WOOPS) So I'll proceed to adjust the rears to where they have just a slight drag and hopefully that will solve the issue!
Adjust 'em up on jack stands, pump the pedal a few times, then back up, and STAB the brakes a few times as well. (thats how the self adjusters are supposed to work.)
Old Feb 15, 2024 | 05:57 PM
  #62
1996 B2500's Avatar
1996 B2500
I adjusted till I felt a faint drag at the wheels, started it up and pumped the pedal a dozen times. About 3 and a half above the floor I had firm brake. I then hammered on the pedal in reverse with both feet a few times, the brakes felt way better. Then, I took it for a short drive and made a few stops. I had good firm brake after pressing the pedal down about an inch each time. So should I consider it fixed? Or maybe give it another couple notches on the adjusters?
Old Feb 15, 2024 | 06:02 PM
  #63
Leave the adjusters alone at this point. It it possible to get the brakes TOO tight, and that's not a good scene either. Could try doing the reverse trick another time or three, and see what happens. So far as I know, that method won't overtighten the brakes.
Old Feb 15, 2024 | 06:54 PM
  #64
1996 B2500's Avatar
1996 B2500
I'm just gonna leave it be, having firm brake after only an inch of pressing down travel is like it was before
Old Feb 15, 2024 | 09:16 PM
  #65
That sounds like a good plan.
Old Feb 16, 2024 | 10:11 PM
  #66
ol' grouch's Avatar
ol' grouch
You have to have a little travel for the brakes to release. Sounds like you have good pedal.
