Sudden Drop in RPM and power
Hello from sunshine state. 2000 Dodge van 3500 V8 5.9L 130.000 miles
Brand new battery rode like a dream for a 3 hour trip then suddenly boom. RPM dropped engine light on and No Buss for seconds then back to normal.
Today it went off again no warning, Pulled aside waited few after few tries of no start than back to normal.
Am I looking at PCM 100% ?
Yeah, the cluster on yours gets all its information via the communications bus. Which is what is going away..... Sometimes, the engine will still run just fine, just, no gauges....
It sure sounds like just a bad connection somewhere though. May not hurt to go thru the connectors, make sure they are clean, and making good contact. There ARE a LOT of them though.... so, time consuming/tedious project....
Makes sense. I will be spraying electric cleaner on connections as well. My concern is I can not risk the possibility of the van just shutting off while driving again.
Is there a way to test the PCM itself or perhaps run codes ?
Trending Topics
New PCM it is.
Any other suggestions beside tracking wires and cleaning Connections?
Should I also change the TPS, Crank shaft sensor and Intake sensor ? They are very cheap. Will that be ideal and recomneded ?
