Plenum Gasket - Ram Van 5.9
Old Oct 9, 2024 | 12:44 AM
  #21
1998DodgeRamVanCamper's Avatar
That sounds like a good idea. However, I'm in California. It's a misdemeanor to even SAY mineral spirits in public here.
Old Oct 9, 2024 | 02:30 PM
  #22
I'm thrilled to say that no intake bolts broke removing the intake.
And the harmonic damper wasn't even worn where the seal rides on it, so I didn't even need to use the sleeve that Felpro provided in their kit.
Old Oct 9, 2024 | 02:35 PM
  #23
The van is at 100,000 miles (almost exactly).
The timing chain had 5/8 inch of deflection. The new double roller I bought from Hughes has 3/8 inch deflection.
I forgot to take a pic of the new chain, but boy it was pretty! Haha!
Old Oct 9, 2024 | 02:39 PM
  #24
A little water pump **** for you.
The original pump looks and feels like new, but I’ve replaced it with another OEM Mopar pump so I figure this one will last the life of the van. Especially that the coolant was probably never changed in the past 25 years.
Old Oct 9, 2024 | 02:42 PM
  #25
The injectors look disgusting. I bought new O-rings and an inexpensive kit to test/clean the spray nozzles. I’m very curious to see how they spray.
Old Oct 9, 2024 | 03:01 PM
  #26
One of the side brackets on the radiator had broken its solder joint loose. Also, the core looked looked really full of crud. I never had any cooling problems at all, but, since the radiator was already out., I decided to take it to a local radiator shop who charged me $110 to unsolder the top, clean the core and solder everything back together. I was considering buying a three row aluminum radiator, but this one was already doing an excellent job so…
Before:
After:
Old Oct 9, 2024 | 04:38 PM
  #27
The radiator cap is worn out. (The return spring on the coolant siphon valve is shot)
Old Oct 9, 2024 | 04:41 PM
  #28
I decided to take advantage of the intake being off and had a look at the carbon buildup on the valves with a borescope. I don’t know about you, but I expected to see a lot more carbon than that. I’m not even tempted to clean them. OK, well, if I’m honest about it, I AM tempted, but I’m not going to. Haha!
Old Oct 10, 2024 | 05:28 AM
  #29
alloro's Avatar
alloro
Van & CUV Section Moderator
If it ain't broke...don't fix it!
Old Oct 11, 2024 | 02:30 AM
  #30
If it ain’t broke, paint it hot pink.
