2000 Ram Van not Starting
Not sure what you are getting at here..... What do you mean by 'return'??? The coil is powered via the ASD relay, PCM controls the ground side. It breaks the circuit to fire the coil.
Well, turns out the plug had almost no gap. I must have dropped it into the plug cylinder too hard and bent it or maybe I dropped one on the ground and forgot? I gapped them so they should have been good. 🤷♂️
I will still take a look at the spark directly off the new ignition coil just to see if it’s blue.
HeyYou, I’d have to draw the circuit to better describe my question, but I guess it’s OBE now. It seems to be working fine with the new plug gap.
Thanks again for y’all’s help! I’m super appreciative of this community.
