1997 dodge B3500 ( HELP ) cant switch from defrost to floor heat
Old Feb 4, 2025 | 09:37 PM
chatvmax's Avatar
chatvmax
Default 1997 dodge B3500 ( HELP ) cant switch from defrost to floor heat
I have a 1997 B3500 Van , 5.2L
No matter what I select I cannot get the air to blow on the floor ,
It blows only as defrost mode,,
I'm an someone please give me some steps or things to check as it's FREEZING in the NE and we have a trip coming up in 2 days ,,
Thank you
Old Feb 5, 2025 | 06:10 AM
Busted Nuckles's Avatar
Busted Nuckles
Vacuum hose from intake manifold to climate control unit not hooked up or leaking. No vacuum means default to defrost only.
Old Feb 5, 2025 | 09:06 AM
chatvmax's Avatar
chatvmax
Default follow up ,
Can you please tell me where that attachment might be, the location of those hoses where I can look, do I have to remove the engine cover shroud, or is it under the hood from the front? Or even perhaps inside the cab??
Old Feb 5, 2025 | 09:15 AM
dodgetruck2's Avatar
dodgetruck2
The post is correct in that you most likely have a vacuum leak, however it may not be directly the hose to the intake. Have you done any work in the dash or engine area recently? That most commonly what happens, you accidently knock a fitting out. However the port for the vacuum accessory circuit i believe is drivers side of the intake keg below the throttle body.
Does your cruise work? could quite possibly indicate the vacuum circuit is ok and you have a different issue.
Old Feb 5, 2025 | 02:10 PM
alloro's Avatar
alloro
Van & CUV Section Moderator
You have to remove the engine cover, then the air cleaner assembly. From there, look on the passenger side of the intake manifold, about halfway back on the side of the intake will be a fitting with a vacuum hose, that's the one that drives the HVAC controls. From the intake it runs to the vacuum reservoir located under the passenger headlight.
The red arrow is pointing to the fitting.
Old Feb 5, 2025 | 02:52 PM
chatvmax's Avatar
chatvmax
Default yes cruise works fine ,,,
Cruise works fine.
I did not do any work recently,,,
I did find the 4 vacuum hoses,,,, they look ok ,,
UPDATE
When I click it from defrost to buy level now I get air blowing out of the center vents and air blowing out of the top on defrost but still nothing on the bottom, I'm not sure what I did to achieve that, perhaps I didn't notice that it would work in that position, but just to be clear the only thing not working now is trying to get it to blow out on your feet,
Again cruise control works and this vent system does work partially
Last edited by chatvmax; Feb 5, 2025 at 04:43 PM. Reason: update partially working,,
Old Feb 5, 2025 | 02:56 PM
Roshi's Avatar
Roshi
I replaced the check valve underneath the radio coming from climate controls to fix mine, was all gunked up.
Old Feb 5, 2025 | 05:33 PM
chatvmax's Avatar
chatvmax
Default how did you get to it
Did you have to pull the radio out or could you reach up underneath from behind where the gas pedal is
Old Feb 5, 2025 | 05:40 PM
Roshi's Avatar
Roshi
Nope just took off doghouse to access all of such stuff.
