96 Dodge RV 3.9 L/32RH transmission oil pump
Old Feb 8, 2026 | 01:03 PM
sealow's Avatar
sealow
Default 96 Dodge RV 3.9 L/32RH transmission oil pump
Hi, Everyone;
I am a DIY; About 2 years ago, went to pay my respects ( Memorial Day ) for two friends at the VA Cemetery in Boulder City, NV.
The trip was fine the Dodge Ram Van 2500 with a 3.9L V6 magnum engine did good. Park the van and WALLA a pool of transmission oil came out very quick.
parked for two years in my garage, missed my fishing van/camper. Question: Do I need to tighten the Front Band to hold the front clutch in place, before removing the oil pump from the transmission ?
GOD BLESS AND THANK YOU
Stay safe.
Old Feb 8, 2026 | 06:19 PM
I don't have a direct answer for ya, but, there are full-sized truck service manuals available here, that *should* answer your question.
Old Feb 8, 2026 | 09:49 PM
wheily's Avatar
wheily
you can it wouldnt hurt. the pump will come out with just holding down on center shaft but does take some force to get it out of case
Old Feb 9, 2026 | 06:22 PM
Moparite's Avatar
Moparite
Did it come out by the converter? May just be the seal. No need to pull the pump out to replace that.
Old Mar 4, 2026 | 06:47 PM
sealow's Avatar
sealow
oil pump is done, fixed.
Old Mar 18, 2026 | 12:13 PM
sealow's Avatar
sealow
Hi, need a bolt cross pattern for the 3.9L 6 cylinder oil pan .
thank you
