Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Acid Rain all over my windows
Old Sep 9, 2004 | 02:50 PM
BlakeAF96's Avatar
BlakeAF96
Default Acid Rain all over my windows
Gooood, this is aggrivating. I had Acid Rain spots everywhere, but I got it all off my paint for the most part, but NONE whatsoever has come off the windows (the only thing I did to the paint to get it off was polish, and more polish).. What can I use to get the spots off of my windows? It's all over the sides and back.. IT SUCKS! Thanks..
Old Sep 9, 2004 | 09:26 PM
Rob_K's Avatar
Rob_K
Default RE: Acid Rain all over my windows
Are you sure it's acid rain? It could be mineral deposits from the rain.
First try straight vinegar. Put it in a spray bottle, mist the window and let is sit for
a minute. Don't let it drip down on to the plastic. Put some rags on the bottom.
Try several applications wiping inbetween each and after letting it sit.
If that doesn't work, you can try one of two things. One is contact cement cleaner. Try it in a inconspicus area first to make sure it doesnt fog the glass. That stuff removes anything.
Lastly, One Grand makes glass polish. You can get it here:
http://www.topoftheline.com/glasspolish.html
It looks like it's on back order right now but call them for availability and any other suggestions. They are very helpful
Old Sep 10, 2004 | 03:49 AM
DusktilDawn Hemi's Avatar
DusktilDawn Hemi
I you have a one sided extremely sharp razor blade. Just take that and spray the window with vinegar and scrape down...that should do it. I used a razor blade to clean my winows all the time. it works
GETTTERDONE!!!!
Old Sep 10, 2004 | 02:20 PM
BlakeAF96's Avatar
BlakeAF96
I tried the Vinegar idea... it didn't bring NOTHING off of it. I even tried spraying Vinegar, then letting it sit, then using a BRAND NEW SHARP RAZOR and it still didn't take ANY of it off. So I've tried Windex, Alcohol, Baking Soda, Vinegar.. Any other ideas or anything?
Old Sep 10, 2004 | 04:46 PM
scrizzle's Avatar
scrizzle
I thought you said the dealer was going to acid wash the spots off for you.
Old Sep 11, 2004 | 06:39 AM
northkuntrykid's Avatar
northkuntrykid
If you go to the "EXTERIOR" forum, theres a good article under "Autopia Detailing guide" on cleaning with clay. It says it works good on glass too.
Old Sep 11, 2004 | 04:13 PM
BULLDOG's Avatar
BULLDOG
I had a very similar problem, I thought that I was actually going to replace a windscreen. Like you I tried everything, then I was told about an off the shelf product from "Rain X" it is there deep cleaning compound. It is actually toothpaste. It worked a miracle for me, unbelievable results. I'm 99% positive this will work for you. If you need a picture of the product let me know.
Old Sep 11, 2004 | 06:31 PM
BlakeAF96's Avatar
BlakeAF96
I thought Rain X was for spraying on your front windshield so you don't have to use windshild wipers???
Old Sep 11, 2004 | 06:58 PM
AdamB's Avatar
AdamB
Rain-X makes a wide variety of water and soil-repelling solutions for glass, paint, and marine applications - the wipe-on stuff your thinking of is probably their most well known product. I suspect Bulldog is referring to the 'Rain-X Glass Polish' offering that supposedly makes removing tar, oil and mineral deposits a snap. I haven't ever used it myself but it's widely available at retail outlets. I'd be curious to know if it works for this application.
Old Sep 11, 2004 | 07:02 PM
AdamB's Avatar
AdamB
In fact you can read about it here:
Rain-X Glass Polisher
At the bottom of the page - there is a picture of the bottle/package it comes in as well.
