Bedliners
Its time to put a bedliner in my new truck. I know that I am not getting a drop-in one. I was wondering what brands of spray-in liners yall have and what you think about them? Some too pricey, or some over hyped....
Line-x here. I have some pictures in my gallery.
I realy like it. even though I had alot done and it did run me a bit, I got a good deal on the step bars and bed rails.
since I had the rockers sprayed he sprayed over the rails for free which is normaly $50 more![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
if I just had the bed itself done I would have walked out the door $437.
I had been to the Line-x shop before and chatted with the guy that does the work. what sold me was the owner of the store cought wind that the first truck he sprayed was involved in an accident, the bed was pretty much gone, but the liner had not cracked, only faded a bit. The owner had taken a chunk out of the middle of the bed for show so you can see that even though the edges are 1/4 inch thick, so was the center of the bed.
When I pulled up to drop my truck off they had JUST finnished spraying the entire inside of an E-350 15 passanger van. the guy uses it to haul stuff and every inch of the interior was sprayed. looked very nice.
one other thing that I also notice about Line-x is the absence of heat. my little toyota's dropin liner gets hotter than hades when out in the sun. my Line-x liner just gets slightly warm to the touch
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
I'm a LINE-X dealer.
All tires are made of rubber but tires can have very different physical properties. The same goes with bedliners.
Let me know if you have any questions.
I've heard Rhino-Lining is amazing material and the way to go, but Line-X is good also.
-Matt-
-Matt-
Trending Topics
For me, it came down to Rhino Liner vs Line-X.
I went with Line-X because of their nationwide warranty and the local dealer's excellent customer service. I've dropped and dragged stuff across the liner that probably would have cut or at least severely scratched a normal drop-in liner, but didn't leave one scratch on the Line-X.
LINE-X and Rhino differ quite a bit. The biggest difference is that LINE-X contains polyurea and Rhino does not. Polyurea enhances the bedliner’s properties: 1. LINE-X's temperature tolerance is 250 degrees and Rhino's is 175. As the temperature of the bed approaches the temp tolerance, it loses its strength. 2. Polyurea keeps moisture out of the solution thus making a more dense and solid liner. Less moisture also means better adhesion. 3. Polyurea also makes for a tougher liner. The tear strength of LINE-X is 304 pounds per linear inch (pli). Rhino is 145 pli. 4. Polyurea sets up very fast, that's one reason why LINE-X goes on with heat and high pressure. LINE-X dries in about 4 seconds, so you get an even application throughout the bed. Rhino takes a minute or so to even gel, an hour or so to dry. Before it gels, gravity can pull the liner from the top ridges in to the low valleys. Rhino’s Tuff Stuff goes on cold/low pressure and thus has that “cottage cheese” or “rain on the windshield” look. LINE-X’s high heat/high pressure system gives it a very nice finished and more consistently applied texture, it’s sort of like an orange peel. The dealer can vary the texture from smooth to very rough. 5. Polyurea makes the liner more chemical resistant, especially to organic oils and solvents.
