Dodge Ram The full size truck that leads the way in innovative and unique styling, the Dodge Ram. With best in class available horsepower, the Dodge Ram out runs any competitor.
Bigger Tires for 2500
Old Mar 16, 2004 | 08:35 PM
04MOPAR's Avatar
04MOPAR
Default Bigger Tires for 2500
Whats the biggest tires I can put on my stock '04 2500 4x4? The 17's are just too small for this truck.
Old Mar 16, 2004 | 08:58 PM
356MAGNUM's Avatar
356MAGNUM
Default RE: Bigger Tires for 2500
I have heard quiet a few guys and/or gals putting on 315/70R17 with no rubbing on 1500's. I would assume (and we ll know what happens when we do that) that with the higher suspension they should fit fine. Also being a 2500 you have the luck of having a solid axle and the A-arm issue rubbing in nil. The companies are starting to put out 20" off-road tires since the popularity of the Dodge 20" rims. If you give me the tire size you have now i have a lil spreadsheet that calcs the overall height. And then you can go from there.
Old Mar 16, 2004 | 09:12 PM
04MOPAR's Avatar
04MOPAR
Thanks RAM, Right now im running the Factory tires 17x8 or 265/70-17.
Old Mar 17, 2004 | 11:55 PM
sbutter21's Avatar
sbutter21
Actually let me clarify what you have.
Your wheels (rims) are 17x8
Your tires are 265/70R17, about 31" tall.
I have read that 315/70R17 will fit fine on the 2500 4x4's.
Keep in mind that some shops might give you a hard time about changing tires since the 2500 comes with Load rating E tires. I believe BFG makes an AT tire in the size 315/70R17's with an E load rating.
My 2500 4x4 CTD came with Michilin(sp) on-off road tires. Not the best off road, but I've heard reports they last 70k+ miles. I'll be keeping them for a while because it's nice to drive a stock truck some times (I have 2 lifted/modified vehciles that I tow with my Ram).
Good Luck,
Sam
Old Mar 18, 2004 | 06:58 AM
356MAGNUM's Avatar
356MAGNUM
Those are the same as I have on mine. They are 31.61" tall.
The 20" tires that come optional are 275/60/20 and they are 32.99"
The 315/70/17 are 34.36"
Here is the formula ((((width*(ratio/100)/25.4)*2)+rim))
((((275*(70/100)/25.4)*2)+17))
Old Mar 18, 2004 | 07:11 AM
04MOPAR's Avatar
04MOPAR
Thanks Guys, Im gonna check out the 315/70/17's and see if they will work.
Old Mar 20, 2004 | 05:09 AM
2x4ramman's Avatar
2x4ramman
Ihave a question for anyoe who might know the answer. I havea v6 dodge ram with flowmasters, throttle body spacer, kn intake and running 285 75 16's can i go to a 315 or is that going to hurt my engine or trany.
Old Mar 20, 2004 | 04:36 PM
356MAGNUM's Avatar
356MAGNUM
Just to let ya know the 285's are 32.83" as the 315's are 34.36" Just need a speedo correction.
Old Mar 20, 2004 | 10:38 PM
2x4ramman's Avatar
2x4ramman
Its just that several people have told me that i will losa a lot of power and might have transmition problems. But like you are saying its only a matter of inches. What do u think bro. I think i want to go with thorn birds for the looks, im running bfg mudders no but want a more aggresive look. Im getting a 3inch body this week and i have a 2inch coil spring spacer kit and add a leafs on it now, think i can fit 35's
and finnaly how do u set up a pic on here?????????
Old Mar 21, 2004 | 02:46 PM
356MAGNUM's Avatar
356MAGNUM
I posted to your post on how to upload pics.
