rear diff question
rear diff question
I have an 04 HEMI QC 4x2 1500. It's got just about everything I want except the limited slip rear diff, so I want to know if anyone has gotten an aftermarket limited slip or locking diff. This is a street truck, so I don't want an air-locker or anything like that. Got my Jeep XJ for the offroad stuff
Can someone please let me know which axle these HEMI Ram 1500's have so I can also search the internet by axle?
Thanks
Thanks
RE: rear diff question
You probably have a 3.92 ratio in your current rear end. But to confirm that need to look at the orginal window sticker and see if it has code DMD=3.55 or DMH=3.92. Check on the tag on the 'pumpkin' will have the code there, too.
There is a factory option to put a limited slip 3.55 ratio. May need to reprogram speedometer, etc.
[IMG]local://upfiles/4343/Fd920339948.jpg[/IMG]
I know it is in fact a 3.92. I don't want to change the gearing, just get a new diff like a POWERTRAX or something that will eliminate the one-tire-fryer issue.
With my axle question, I was hoping to find out which specific axle these trucks come with such as a DANA 60?
I'm trying to determine if my truck has the limited slip (TRAK LOCK) differential. I crawled under the truck and a white label on the rear axle drivers side says "3.55 4x2 STD open 9.25"
The VIP Dodge dealer Summary Report says I have the option called "Axle-Rear, Corporat 9.25 LD".
Here is my VIN: edited vin out Thanks Bill 2001 Dodge Ram 1500 Laramie 4x2 SLT/Quad Cab/Short Bed 5.9L gas
