Dodge Sprinter The Dodge Sprinter is all function, with styling cues from the Dodge Truck line, it makes the workaholic's job much easier. Check out the Dodge Sprinter in showrooms today!
Replacing Oil Fill Tube on 2007 Dodge Sprinter Mercedes
Old Oct 29, 2011 | 03:28 PM
jjamie99515's Avatar
jjamie99515
Unhappy Replacing Oil Fill Tube on 2007 Dodge Sprinter Mercedes
Help,
I had to have the fuel pump and all fuel injectors replaced on my 2008 Itasca Navion RV which has a Mercedes engine. This was done at a Dodge Dealership in Fairbanks, AK. A few days later driving down the Alaska Hiway I noticed a oil leak coming from the top left part of the motor. I was told at a truck stop in GA that the oil fill tube was broken so I ordered another one. I want to replace the tube without going back to a dealership and having to pay again for a simple fix. Any suggestions on how to replace the fill tube? Thanks
Old Oct 29, 2011 | 11:00 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I'm guessing you have a 3.0 diesel engine.
3.0L Turbo Diesel/Lubrication/TUBE, Oil Level Indicator/Removal
REMOVAL
Labor Operations: Click to display a list of Labor Operations associated with this procedure
1. Remove the generator bolts and position the generator aside.
2. Remove the upper oil level indicator tube bolt.
3. Remove the lower oil level indicator tube bolt.
4. Remove the oil level indicator tube.
Old Jul 7, 2012 | 11:23 PM
ALASKAPF-185's Avatar
ALASKAPF-185
Oil fill tube, short 6-7" pipe with removable cap. Use an 8 mm 12 socket or even better an 8 mm ratcheting box end wrench from gear wrench (brand) and remove 1 bolt holding the tube to a metal bracket just below the cap. Twist entire tube counter clockwise 120* lift up and out. Install in reverse, do not over tighten the bolt as it is usually 1-2 mm short from going thru the welded on nut on the bracket. It should be like 48-60 in/lbs. So not tight at all.
