Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
hesitation
Old Apr 21, 2007 | 10:16 AM
gwilkrrs's Avatar
gwilkrrs
Default hesitation
car 1992 rt non T 150k miles.
car hesitates when cold.
car stutturs at any given time any given speed, not bad but noticable.
i stood on the gas to merge into traffic it stuttered and backfired.
whats wrong and how to fix.
Old Apr 21, 2007 | 11:17 PM
92stealth's Avatar
92stealth
Default RE: hesitation
mine has been doing the same thing, but its a turbo car. i think it might be the ecu with the leaky capacitors.
Old Apr 22, 2007 | 10:02 AM
gwilkrrs's Avatar
gwilkrrs
how do you fix?
the car is only doing it sometimes not all driving.
Old Apr 22, 2007 | 02:57 PM
92stealth's Avatar
92stealth
if it is the ecu then you can go on 3si.org and there are people that will fix them for about $250 from what i have read. if you want to know if it is the ecu then remove it and see if the caps were leaking.
Old Apr 23, 2007 | 01:39 PM
thestealth's Avatar
thestealth
A faulty ECU can cause a host of problems. If you have a first gen car that hasn't had the capacitors replaced, chances are that could be the problem. It is not a matter of if, but when. ECMTOGO.com will get you fixed up for about $250.
Before jumping to conclusions though, have you checked the plugs, wires, air filter, fuel filter? Any of those will cause hesitations.
Old Apr 24, 2007 | 12:31 PM
92stealth's Avatar
92stealth
with my car its more as if it has a dead spot. right before the boost or while im on around 3 psi (acording to the stock gauge). i have feeling it is the ecu considering the car is a first gen and i dont thing they were replaced.
Old Apr 28, 2007 | 02:47 PM
gwilkrrs's Avatar
gwilkrrs
i recieved my car from my father in law so i know its history.
recent total tune up
trans rebiult 9 monthe ago
general maintenance otherwise
Old Jul 16, 2007 | 06:50 PM
gwilkrrs's Avatar
gwilkrrs
nwe ecu and ecs computer. still stutters and hesitates. any other help[?
Old Jul 17, 2007 | 11:35 PM
yevgenievich's Avatar
yevgenievich
fuel or spark problem
