shifting hard
shifting hard
I have a 93 ES and my car had been shifting hard lately. Sometimes, it takes a lot of force for me to get it in first gear and this continues throughout the gers, often, 3rd gear will girnd. Other times, it will shift smoothly. Today, I drove my car to work with it being hard to shift, but on the way home, I could shift very smoothly. Any ideas?
RE: shifting hard
yes.. ill be watching this topic because mine does the same thing.. like when ur at a light and u have to go into first sometimes it doesnt go in so i throw it into second then back into first and it usually goes right in and third grinds sometimes maybe just one tick into third..
RE: shifting hard
i had the same problem and a s a result i had to get a new transmission for my TT ($3K):-( check the transmission fluid if its like mine there is no guage or level stick so you have to go in underneath and check it manually...there is an upper bolt that you need to remove...stick your finger in the hole and if you can feel transmission fluid underneath your finger then u have a problem i cant solve...my tranny was running completely dry for about a hundred and fifty or so miles and i burnt out my gears...and it was shifting hard throughout all of them and would often pop out of reverse and was very hard to downshift...try this and let me knowif it was helpful
Trending Topics
