Dodge StealthThe car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
If you're capable of electronics repair, you could do it yourself. I've had good dealings with ECMTOGO.com, others have had good luck with AVPRO.com (both ECU rebuild companies). I've picked up a rebuilt ECU at OReilly.
well my buddy is very good at this stuff so im going to get a hold of him if it is the problem. and how would i flash it to get the check engine light off
if the ECU is bad, you need to clean the boad, and soder on new capacitors. You're best off sending it to someone who knows what they are doing. www.avproecm.com
