Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
need help
Old Sep 17, 2010 | 11:43 AM
91stealthguy's Avatar
91stealthguy
well got the meter last night for about 10 bucks but i havent taken out on the road but it dies when ur moving it like under 10 mph but the guy said it was the TPS so idk going to see what i come up with on codes now
Old Sep 17, 2010 | 12:27 PM
91stealthguy
just did a test and got 20 + sweeps depends on what setting i was on would be all long sweeps or all short and from what im seeing that that means nothing is there
Old Sep 17, 2010 | 04:30 PM
91stealthguy
ya the car runs like crap and dies when im in gear and has a check engine like but not getting any codes
Old Sep 21, 2010 | 11:17 AM
thestealth's Avatar
thestealth
If you are getting rhythmic sweeps, that does indicate no issues with the ECU. It's odd though, the CEL shouldn't come on unless there is problem...at least that is my understanding of it. Is the CEL on all the time or just when the car dies?
Old Sep 21, 2010 | 11:24 AM
thestealth's Avatar
thestealth
From Stealth316.com
If there is not a code displayed, the ECU itself may be faulty.
That is a common issue with the first gen stealths...
Old Sep 22, 2010 | 01:13 AM
91stealthguy
and thats under the dash right but why would the car when u first start it run fine but as soon as u shut it off and start it again it wont run
Old Sep 22, 2010 | 09:33 AM
Girly TT's Avatar
Girly TT
Well, if you would explain in as much detail as possible, the problems you are having, maybe we can help you figure out where the problem lies.
Old Sep 22, 2010 | 09:36 AM
Girly TT's Avatar
Girly TT
Pull your ecu out, open it up, and check the capacitors. I'll bet you they're leaking.
Old Sep 22, 2010 | 10:00 AM
thestealth's Avatar
thestealth
What she said...
Old Sep 22, 2010 | 11:13 AM
91stealthguy
ok doesnt matter when i start it fr the first time that day but the very first start runs good but i move cars alot before i start working on them so i have to shut it off to move other cars so when i get back in it to start it i have to be on the gas to keep it running cause it will idle under 500 and the check engine light is on but im not getting any codes but it will run like that until the next cold start or if the car gets about 45 which i never had it over 5 mph in my yard cause its not reg yet
