Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
1991 Stealth DOHC starting problem
Old Jan 26, 2025 | 03:49 PM
owt's Avatar
owt
Unhappy 1991 Stealth DOHC starting problem
I recently had the heads reworked because of a timing belt slip. The car will start on starting fluid but dies when out of fluid. Have fuel at the fuel rail I'm guessing that the injectors are not firing. Fuel pump is pumping. I have checked for any loose or wiring not connected and can find none, it ran fine before the belt slipped. Any suggestions would be appreciated.
Old Jan 26, 2025 | 05:01 PM
Does it run ok on starting fluid??? That's an interference motor, so, if the belt slips far enough, or breaks..... you get bent valves. Try a compression test??
