Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
could this be an ecu problem
Old 12-08-2004, 12:36 PM
thestealth's Avatar
thestealth
thestealth is offline
Default RE: could this be an ecu problem
No. Usually if it was bad after the swap, it was bad before the swap...
I have never replaced the PTU, but it appears to be plug and play with just a few bolts/nuts holding it on. I would have to give it a closer look to know for sure. I am at work no, but at lunch time I can give it a look.
*edit: Ignition signal is; Engine sensors (CAS & MAS)---> ECU----->PTU---->Coils---->Plugs
Old 12-21-2004, 07:04 PM
Ranch's Avatar
Ranch
Ranch is offline
Got the rebuilt ecu back and installed a week ago. Logged about 100 miles since without a problem.
Old 12-21-2004, 07:41 PM
thestealth's Avatar
thestealth
That is good news. Happy cruising.
Quick Reply: could this be an ecu problem
