Transaxle flush with ATF+3
Old Nov 10, 2004 | 04:24 PM
derone's Avatar
derone
Default Transaxle flush with ATF+3
All,
I've read alot about the mopar trannies and some recommend only using the ATF+3 fluid from the dealer for use. I've seen QuakerState ATF+3 and was wondering if anyone else had tried it or recommends it.
Anyone?
Doug
98 stratus 2.4L auto
Old Nov 15, 2004 | 01:06 AM
derone's Avatar
derone
Default RE: Transaxle flush with ATF+3
Well another site said it was ok...think it was allpar.com or something like that. So I changed the fluid and filter today. Didn't flush it, but then a 4qt change is better then nothing. If your fluid ain't red, it probably needs to be changed.
Doug
Old Nov 15, 2004 | 01:27 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
i power flushed mine, and used valvoline maxlife atf.
Old Apr 19, 2006 | 12:52 AM
John_E's Avatar
John_E
How often are you guys changing your ATF? (I am thinking of 40k mi, for mostly city driving.) I don't believe this "lifetime" recommendation in most new cars, although I am glad to see a 45k mi recommendation for severe service.
Old Apr 20, 2006 | 07:58 AM
TomStratRT's Avatar
TomStratRT
At least once every 2 years I flush mine.
Old Apr 21, 2006 | 05:16 PM
dakotaquadsport's Avatar
dakotaquadsport
ORIGINAL: derone
All,
Anyone?
Doug
If I'm not mistaken ATF +4 replaces +3 and is now recommended for use by Chrysler.
Old Apr 24, 2006 | 11:53 PM
John_E's Avatar
John_E
ORIGINAL: dakotaquadsport If I'm not mistaken ATF +4 replaces +3 and is now recommended for use by Chrysler.
Be careful. I just read the TSB, which lists numerous Chrysler cars, including the pre-2005 Stratus, which must be kept on ATF+3.
Old May 25, 2006 | 08:10 AM
detroitdieselman's Avatar
detroitdieselman
I was just told by my dealer to use 4 in my 01 when I changed fluid, that`s what i did. They said that`s what they put in all the older cars that had 3 in them when they do any fluid changes. So far so good.
