2004 dodge stratus shaking problem
Old May 14, 2010 | 09:37 PM
brakepad's Avatar
brakepad
Default 2004 dodge stratus shaking problem
Hi all,
I have this 2004 dodge stratus 2.4 with 75K miles on it. It started shaking at low RPM couple weeks ago. I just noticed that when it shakes, all the lights, including head lights, dash board lights, and the roof light. What could be the problems? Thanks.
Old May 14, 2010 | 10:56 PM
ratsttam's Avatar
ratsttam
What do they do?
It would also help to know if you have a sedan or coupe, and which engine you have, previous maintenance, etc... the more you tell us, the more we can help you.
Old May 14, 2010 | 11:37 PM
brakepad's Avatar
brakepad
Originally Posted by ratsttam
What do they do?
Thank you for your replay. This is a 2004 dodge stratus sedan. 2.4 I4 engine. No previous maintenance was done except oil change. I don't drive much, so I change engine oil every six months. The engine light has been on for a few years. The code read was something with the emission system. No problems before. The car started shaking at low RPM couple weeks ago. The engine stopped running once at a traffic light. Today, I noticed the lights flash when the car shakes. When the lights flashed, they didn't go off but just went dim. The car shakes at parking too.
Old May 15, 2010 | 08:26 AM
pearl01stratcpe's Avatar
pearl01stratcpe
Sounds like either worn out motor mounts or the timing is off a few teeth.
Old May 15, 2010 | 09:27 AM
brakepad's Avatar
brakepad
Thanks for the input. Could the worn out motor mounts cause the lights flash?
Old May 16, 2010 | 08:56 PM
pklein's Avatar
pklein
hi i have an 04 dodge stratus with the 4 cylinder dohc engine, i have also had the same problem. my car shakes and/or stalls at almost every light i stop at, my lights also dimmed. i have had the codes pulled and its the o2 sensor in the first bank, thats what the "emission system" means, i hope this helps o2 sensors are only about 32 bucks. what else helps is pick up a haynes repair manual they work wonders! hope this helps if you have any questions email me at pklein1390@aol.com and put the subject as "stratus".
Old May 18, 2010 | 08:30 PM
brakepad's Avatar
brakepad
Thanks pklein. Maybe I should take the car to autozone to have the code read.
Old May 19, 2010 | 10:22 PM
pklein's Avatar
pklein
Your welcome, just make sure your check engine light is on so they can get an accurate reading
