01 Stratus RT... Clutch and flywheel?
Old Dec 25, 2010 | 05:13 AM
cookiebearz32's Avatar
cookiebearz32
Question 01 Stratus RT... Clutch and flywheel?
Hi. I just bought a 2001 Stratus RT with 5 speed transmission with a little more than 80K miles. Actually I got it on base from a military auction, in hopes of it needing an easy fix..
So... It starts and everything, the only problem is, when I put it in gear, it goes no where. I know, there was a thread on this before, but I didn't find anything to help me. I've looked everywhere!
Whether I use the clutch, to put it in gear, or not.. it does nothing. RPMs go nowhere, unless I give it gas. No knocks, whirring, whining, scratching, nothing! I've gotten quite a few opinions on it, other than mine. I'm being told my clutch is pretty much shot. So I've ordered one already, it's a Exedy OEM clutch kit.
So, I am doing the work myself, to save me a couple bucks.. but I figured while I'm down there replacing the clutch, I might as well throw in a new flywheel so I don't have to worry about anymore problems for another while. Only problem is, I can't find anywhere that has the flywheel for the 3.0 Stratus. If anyone knows somewhere I can find one, at a decent price, I would greatly appreciate it! ..or if anyone has a different opinion on my problem, works as well..
*On top of that, I am stationed out here in Hawaii, so it's tough to get someone to ship out here.. and no auto parts stores have or will ship to me..
Old Dec 25, 2010 | 05:16 AM
cookiebearz32
Also, will a 3.0 Eclipse flywheel fit my car, with the Exedy oem clutch? I read that unless I use a eclipse clutch, the flywheel wont match up.. or vice versa!
Old Dec 25, 2010 | 04:05 PM
cookiebearz32
All I'm really looking for is a part number for the Stratus flywheel, since I've already ordered the KMB03 clutch kit, which I believe is only applicable on the Stratus. I pretty much bought with out doing more research on the interchangeable parts, and I really can't fit (buying more parts than I need to) into my budget.
If someone could help me significantly, perhaps pointing me in the right direction, to find a part number, that would be great!
Old Dec 26, 2010 | 02:05 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
These are all mopar numbers, Flywheel MD379541,Clutch Disc MR553279,Pressure plate MR553278 and Release bearing MR145619. Hope this helps.
Old Feb 15, 2011 | 10:18 PM
cookiebearz32
Aparrently.. that Flywheel part didn't fit my crankshaft. The bolts didnt match up, so now I'm stumped.. because I have the KMb03 clutch kit.. which fit the dowels on the old flywheel.. So.. Idk, maybe they sent me the wrong flywheel?????
ANy advice on where to get a whole kit and be worry free?
