2002 Dodge Stratus ES 2.4L - Code P0432
Hello,
About a month ago my check engine light came on and the following code was read - P0432 Main Catalyst Efficiency Below Threshold (Bank 2).
I had the codes reset and then ran some fuel system cleaner through for one full tank of gas. It stayed off for a couple weeks and then came back on a few days ago with the same code.
I really don't want to take it and have a diagnostic ran just yet, so was wondering if there are things that I can do on my own, or cheaper fixes I can do to start with to correct this problem.
The car is running fine. I don't hear any noises.
I have seen that some replace the oxygen sensors. Should I start with that? Any other ideas are appreciated.
Thank you!
Thank you!
ur problem is most likely to be the Cat. 90k, it is about right for it is go out. And i think Oxygen sensor are like $100 each.
Exhaust are usually the worst rusted out area of the car, fight against Mother nature takes a lot more than just a Service manual.
Federal emission waranty is 8yr/80k, or 8yr/100k in some state. It seems like u expired by date and mileage.
I would say do it at a Muffler shop, they do these type everyday, they should be able to get it done cheap and fast.
