douse anyone have any ideas to help my trunk lid not rattle....... i have 2 12" sony's whith a 1200 watt amp and the only way i can get my trunk to stop rating is when i sit on it........ any sugestions
dynamat works pretty well, its a little heavy. If you do like 3 layers under the trunk interior and on the trunk lid, it should absorb alot of the sound waves and make the trunk stop rattling. Also you might wanna check and see if its the trunk lid or the license plate rattling.
Trust me, i know what your dealing with. I almost had it fixed, then built vented boxes for my type r's, and everything rattles again, along with the roof moving in and out about an inch (see video here) Well anyways, i put some pads where the rubber things hit the trunk (hard to explain lol) and it fixed it before the box upgrade. Im going to be installing fatmat in the whole trunk (great alternative to dynomat btw) and hopefully that will fix it.
It's not on the trunk lid it were the lid latches to the body that "D" looking part that the lid latches too has two bolts you can loosen and move down to tighten the trunk.
