2000 Stratus 2.4L engine problem
I purchased a 2000 Dodge Stratus SE with a 2.4L. 153,000 miles. Previous owner just put new tires and had transmission rebuilt. Problem it had was that it died at a stop light and they couldn't get it started. When you turn the key, the engine sounded like it wanted to turn over, but the battery might have been drained...although everything electrical worked just fine. I bought a new battery and installed it. Same thing. I removed the spark plugs and it turned over much faster, but didn't seem to sound right. Any suggestions as to where to start first? I suspected a broke timing belt, but I'm not sure. Thanks in advance for your input.
update: 2000 strauts engine problem
I checked compression this morning. seemed ok. reinstalled spark plugs and got it to start. it rattled a little and smoked a little. has been sitting for 8 months. ran for about 15 seconds, not smoothly, then died. now it won't turn over at all. any suggestions? BTW, the alternator and A/C belt is off so I know it's not the compressor locked up.
