Engine HELP!!
Engine HELP!!
I have a 2006 Dodge Stratus with a 2.7L V6. The oil light came on, the engine started running rough, and then promptly quit. After this the engine would not turn over. I purchased a low mileage salvage engine (50K) and installed it over the past weekend. After installing it the replaced engine won't turn over. I removed the starter and it spins when you try to start it. I put the starter back in and it attempts to turn the engine over but it doesn't turn it over. It is almost like the replaced engine is frozen up. Any ideas?
Last night I loosened up the engine / tranny bolts and attempted to turn it over. With these bolts loose the engine will turn over. I then began to tighten them and it eventually got to where it wouldn't turn over again. It sounds like you may be correct about it being jammed against the flex plate. How can I get to aligned properly? Will I have to pull the engine to do it?
