1997 Stratus help
Old Mar 16, 2004 | 12:53 AM
ragin_cajuns's Avatar
ragin_cajuns
Default 1997 Stratus help
i have a 97 stratus with 81k miles on it. it runs fine execpt for a squeeking noise from the front drivers side wheel area. it seems to only make the noise when you turn or go over a bump.
any ideas what this might be?
thanks
Old Mar 16, 2004 | 03:57 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: 1997 Stratus help
Sounds like it is just the suspension squeeking, try getting the chassis lubed.
Old Mar 16, 2004 | 08:34 PM
ragin_cajuns
excuse my ignorance but you mean just the grease certs (or whatever they are called) - about 6-8 under the front end?
Old Mar 16, 2004 | 11:37 PM
dodgemech's Avatar
dodgemech
Your Stratus only has 2, maybe 4 if the rear upper B.JB's have them. Your squeak noise is probably the steering gear-commonly known as the rack-n-pinion, tie rods. Both the inner and outer tie rods have been known to make noise going over bumps, especially slow speeds like speed bumps in a parking lot.
Old Mar 17, 2004 | 03:55 PM
ragin_cajuns
hey dodgemech - thanks for the input. i got under the car last night and found that i only have two grease points on the upper ball joints on the front end.
the noise is when going over bumps and steering at slow speeds.
what is the remedy for this? is there something i can do myself?
i took the car into dodge last year when it was makign the sound every now and then and they couldn't locate it. now it does it all the time.
thanks again
Old Apr 17, 2004 | 01:28 AM
Vice King's Avatar
Vice King
i used to have that problem too, i had a friend take it in for me. i think all they did was lube it with grease.
Old Apr 17, 2004 | 10:01 PM
dodgemech's Avatar
dodgemech
The tie rods on those cars have a nasty habit of making noise. Try the outers first-if its inners you need a steering gear to fix it
Old May 1, 2004 | 04:09 AM
iceman33's Avatar
iceman33
You probably have a mouse making the squeeking noise. He probably has built his nest there and when you turn the wheel, it pinches him making him squeek. When you go over a bump, it also makes him squeek because he is uncomfortable. Feed him some cheese before you go anywhere, and this should solve your problem.
Old May 16, 2006 | 03:16 AM
kimberly's Avatar
kimberly
i have a 1997 dodge stratus. i dont know much about cars just what i learned form my dad. (who i cant get ahold of.) my car when in park or drive shakes a little hard and very bad if i go above 50 mph. it acts as if its going to die on me. i think it might be the transmission but i would like someone else to give a idea. please..
thanks
