4G64 won't line up timming marks
Old 04-10-2015, 12:32 PM
steezus_ramirez's Avatar
steezus_ramirez
steezus_ramirez is offline
Default 4G64 won't line up timming marks
I'm trying to replace the head on my stratus but the timing mark won't line up because I can't rotate the engine.. It was frustrating me all day.. Any ideas?
Old 04-10-2015, 12:53 PM
pearl01stratcpe's Avatar
pearl01stratcpe
pearl01stratcpe is offline
Here is the service manual - http://tearstone.com/eclipsefsm/11B.PDF
Is the belt on currently? If not, what wont rotate, the cam gears or crankshaft?
If you havent done already, take out the spark plugs, you may be fighting compression.
Old 04-10-2015, 12:55 PM
steezus_ramirez
I already did take out the spark plugs I was trying to rotate the camshaft sprocket
Old 04-10-2015, 12:57 PM
pearl01stratcpe
The crankshaft might need rotated because a piston might be positioned where a valve is open and touching it. These are interference motors, everything has to be just right
Old 04-10-2015, 12:58 PM
pearl01stratcpe
Shine a flashlight down each spark plug hole and see what pistons are closest
Old 04-10-2015, 01:00 PM
steezus_ramirez
Then after I check which one is closest what do I do?
Old 04-10-2015, 01:01 PM
steezus_ramirez
Also what size is the head bolts and where can I buy them?
Old 04-10-2015, 01:02 PM
pearl01stratcpe
You should be able to determine which way to rotate the crankshaft to allow room to spin the camshaft. The camshaft wont be very easy to move though, with the springs for the valves giving resistance.
Old 04-10-2015, 01:05 PM
steezus_ramirez
I have a breaker bar with and ext.. Thank I'll check it out after work and get back you later.. Is there anything else I might need to know?
Old 04-10-2015, 01:06 PM
pearl01stratcpe
See page 15 of the link in my first post. Im not sure what size the head bolts are, youll have to remove one and either take it to the dealer or any autoparts store. You might be able to get them at a hardware store but its a good chance they are an oddball size. Whatever you do, dont cheap out. Get the strongest ones you can find
Quick Reply: 4G64 won't line up timming marks
