replaced head set timming belt and
Old Jul 18, 2006 | 06:30 AM
bigpoppasalty31's Avatar
bigpoppasalty31
Default replaced head set timming belt and
hello everyone just need a litle help just replaced head in a 98 stratus 2.4l and set timming if it was a little off(1/2 tooth) would it make it sound like a lawnmower when started?started for a second and thats exactly what it sounds like.If it was a 1/2 notch off would that be the rpoblem?thanks,bigpoppasalty
Old Jul 18, 2006 | 05:45 PM
tomthedog's Avatar
tomthedog
Default RE: replaced head set timming belt and
was it loud, like a leaking exaust gasket or did it miss and run like a lawnmower sounds?
even though it's only a half a tooth off, that may be what's wrong. as the motor runs the belt streeeches. in operation it may be as much as 1-1/2 teeth off (that's the reason for the cam position sensor). the CPS can only compensate for so much "play" which may be the reason your car runs bad. let us know the deal, good luck.
Old Jul 20, 2006 | 06:16 PM
bigpoppasalty31
It was missing and sounded like a lawnmower and wouldnt stay running,and local mechanic said it was timing and he would set timing for $40.We will see what happens.thanks,bigpoppasalty
Old Jul 21, 2006 | 12:27 AM
superstrat97's Avatar
superstrat97
thats the sound they make when there are bent valves.[&:]
Old Jul 21, 2006 | 02:44 AM
bigpoppasalty31
no bent valves before i pulled head off it made that noise because timing was not correct.head was puled and took to machine shop and no bent valves.
Old Jul 21, 2006 | 02:25 PM
tomthedog's Avatar
tomthedog
the "timing" is controlled by the computer. what makes you think the timing is/was off? lots of thing can make your car run like junk. don't mean it's junk, could be an elect prob. write back.
Old Jul 24, 2006 | 11:43 PM
superstrat97
there i two types of timing your ignition timing an your cam timing, to time th cams you need to make sure both of he cam timing marks are EXACTLY DEAD ON CENTER wih eachother and the crank marks need to be also. to make sure it is right, rotate the the ening around twice by hand and check to see if evrything i lined up, if it is your timed, if not move whatever cog is of in on tooth increments until it's good. in som of the 2.4's you need a DRBIII to relearn the the cams so the spark timing and cam sensor are calibrated, but on the older ones(like mine) you just need to let it run for a whil until it relearns itself. i hope this more in depth explaination has helped
Old Jul 29, 2006 | 10:41 AM
bigpoppasalty31
what is a DRDIII?tia bigpoppasalty31
Old Jul 30, 2006 | 06:50 AM
bigpoppasalty31
i mean a DRBIII?
Old Aug 1, 2006 | 03:42 AM
bigpoppasalty31
figured out what a drbIII was.thanks,bigpoppasalty
