PREFORMANCE OIL
Old Apr 10, 2004 | 02:01 AM
Shadowboy's Avatar
Shadowboy
Default PREFORMANCE OIL
I should be getting a new 3.0 long-block for the shadow soon
(next week).
But i still dont know if i should go for "good" regular oil OR Preformance
Synthetic oil.
Old Apr 10, 2004 | 03:02 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: PREFORMANCE OIL
Syn will cost more than "regular" oil, but save you money in the long run...the military uses it, and I was a US Air Force "SAC Trained Killer" for 21 years and we never had an oil related problem with any of our vehicles....I swear by it and so do most experienced mechanics...it's factory fill for Vipers, so that should give you a clue....Mobil 1 and Amsoil are the leaders in the industry, Amsoil can set you up for a discount on your oil needs...
Old Apr 10, 2004 | 03:31 AM
Shadowboy's Avatar
Shadowboy
Good stuff, I will.[sm=smiley1.gif]
Old Apr 10, 2004 | 05:44 PM
moparturd's Avatar
moparturd
You probably want to run the first few thousand on regular oil to allow the rings and cylinder walls to scuff in. Also, if you have a leak or your engine starts comsuming oil, let it use the cheaper oil. Then switch to synthetic.
Old Apr 11, 2004 | 11:35 PM
71RoadRunner's Avatar
71RoadRunner
I'll second that, break it in on good 'ol dinosaur crude, then after 5,000 miles you can switch to the full synthetics. I would recommend either Mobil 1 or Amsoil.
Old Apr 18, 2004 | 06:36 PM
Shadowboy's Avatar
Shadowboy
I have talked to my mech-man and have been told
the same... So after my 2nd oil change i will switch.
ps I should have the engine by tuesday
Old Apr 18, 2004 | 07:54 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
What weight of oil do you plan to use?[sm=smiley5.gif]
Old Apr 20, 2004 | 01:00 AM
Shadowboy's Avatar
Shadowboy
Castrol 5W-30
