Challenger start/ignition problem
Old Apr 20, 2004 | 05:56 PM
Challenger70owner's Avatar
Challenger70owner
Default Challenger start/ignition problem
I have a problem with starting my Challenger 1970.
When i turn the key the starter doesn't do anything. Then i tried to shortcut the starter relay with a screwdriver and then the starter will work but i don't have a spark.
Is it the ignition switch? or can it be something else?
Thanks,
Ton
Old Apr 21, 2004 | 03:32 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: Challenger start/ignition problem
I would first replace the starter relay, the problem is probably in it. I don't think it would have started and ran without the key in the "ON" position, so the ignition switch is most likely OK.
Old Apr 21, 2004 | 06:40 AM
Challenger70owner
Hi, Roadrunner,
ORIGINAL: 71RoadRunner
No, it didn't ran.. only the starter itself worked but i don't have a spark.
Sorry if i wasn't clear enough...
Old Apr 21, 2004 | 07:13 AM
71RoadRunner
I thought that might be what you meant, but I wasn't sure. Then it very well could be the ignition switch. Before digging into the ignition, try removing one of the plug wires from a plug and check for spark while jumping the starter relay with the key in the ignition in the "ON" position. If there is no spark, then it looks pretty good that it's the ignition switch. The only other thing I can think of would be simultaneously between the starter relay and the fuel pump, which is highly unlikely.
Old Apr 21, 2004 | 07:28 AM
Challenger70owner
If it is the ignition switch, can i try this:
the + from the ignition coil directly to the battery?
And then try to start with the screwdriver on the starter relais?
If she starts, it's the switch.. or did i miss anything?
Old Apr 21, 2004 | 07:50 AM
71RoadRunner
I don't know, I've never tried it before. I don't know if that will work or not or if it might fry something. I think the ballast resistor and the voltage regulator are between the two, so there might be problems with it. I would hate to see you fry your electrical system. Just pulling a plug wire and checking for spark while jumping the relay will let you know if the ignition switch is OK.
Old Apr 21, 2004 | 07:54 AM
Challenger70owner
Hmmm.. maybe i should look it up if it's possible.
I tried pulling a plug wire and ther's no spark at all..
Old Apr 21, 2004 | 07:57 AM
71RoadRunner
Well then, I would say it's the ignition switch. Check out Allpar.com, they have alot of helpful info. Here is a link to them: Allpar
Old Apr 21, 2004 | 10:54 AM
moparturd's Avatar
moparturd
Some other things that come to mind.
The neutral safety switch in the tranny.
A poor connection at the firewall at the bulkhead connector.
I have had this problem before with my Coronet. I've found that cursing helps alot.[sm=smiley4.gif]
Old Apr 21, 2004 | 12:03 PM
charlie1935's Avatar
charlie1935
On the no run part, the ballast resistors are famous for going bad also.
