Trouble after winter storage... I need help
When I finally decided to bring out my ’96 Indy Ram from winter storage, I found that my battery was dead. Instead of just recharging the battery, I tried jump starting the truck with my battery charger/jump starter unit. Well the unit didn’t have enough juice to turn over the truck, so I ended up having to charge the battery overnight. (something I should have done in the first place).
Anyhow now my engine just turns over without starting. I have no spark, the fuel pump won’t run, and my check engine light won’t come on. I’ve check all my fuses, and relays in the power distribution box, and I also checked all the fuses in the dash panel. Every electrical system seems to work except for the fuel pump and spark.
I’m at a loss right now, and I don’t know what else to do. I fear the worse and think that I might have ruined my Mopar Performance engine computer. Does any one know if there is something I’m missing, or some other test I could do to figure out this problem? Any help would be greatly appreciated.
First thing I would try is to lock then unlock the drivers door with the Key
If you have the factory security system it may be armed!!! and that would disarm it!!
ORIGINAL: JCswm
Thanks, but I do not have a factory alarm. I do have an aftermarket alarm system and at first, this had crossed my mind as the possible problem, but the alarm should only kill the starter, and not the fuel/ingnition system. However I have reprogramed the alarm, and tried the valet over ride to no avail.
First off, buy a new battery. If that doesn't solve it, try leaving the new battery disconnected for about 5-10 minutes, then reconnect it and try again. If it's still dead, it looks like the PCM is fried. Good luck.[sm=smiley20.gif]
ORIGINAL: JCswm
Do you have a Multi-meter and a schamatic??
Yes, I have both. What's the plan?
Trending Topics
ORIGINAL: 71RoadRunner
Although I should go get the battery checked out. I just bought it last summer so if there is something wrong with it, I will get a free replacement.
Thanks
Check the voltage at the DG/OR wire at any injector while cranking the engine
If you have none swap the ASD relay with another relay with the same part #
If you have power at the DG/OR wire and you see no wireing problems your PCM may be dead!!!
**I've seen MANY cars get the wireing harness chewed on by rodents while in storage!!!! Look VERY closely for harness damage!!!
