synthetic question
Old Jun 8, 2004 | 07:42 PM
ramfan5.9's Avatar
ramfan5.9
Default synthetic question
ive heard a few thing about synthetic oil first of all ive heard that if u use synthetic oil it gum up ur engine is that true and exactly y does it do that and the other thing ive heard is if u use it once u cant go back to the regular stuff is that true and y is that
thanx guys
Old Jun 9, 2004 | 02:09 PM
DarkHamlet's Avatar
DarkHamlet
Default RE: synthetic question
Don't know much about that, but i used it for awhile, then change back to Dino oil and had no problems with it.
Besides i did not, hear or felt any difference betwen them. I guess the only one who knows is the Truck and he aint saying
much.... So who knows!
And the engine is working ok.....
Old Jun 10, 2004 | 06:33 PM
sgbofav's Avatar
sgbofav
Ten Myths About Synthetic Lubrication
First Published in National Oil and Lube News by Ed Newman
It's a fact of life that behavior is strongly influenced by what people believe, whether true or not. Numerous examples from history bear this out. For example, sailors were once fearful of sailing outside the sight of land less they would fall off the edge of the world. In the early 19th century, the train was considered dangerous because it was believed that if you traveled faster than 25 miles per hour, you would be traveling too fast to breathe. At a later date, the New York Times warned that electric light may cause blindness. Microwave ovens, automobiles and airplanes have had equally vociferous opponents.
Looking back, it is easy to laugh at some of these things people so firmly believed. But these people were not stupid. They were simply misinformed. In many instances they had simply drawn conclusions before all the facts were in. How easy it is to make the same mistake today. In our own time, synthetic motor oils have been the object of many misconceptions held by the general public. Many people, including some mechanics who ought to know better, have been misled by persistent myths that need to be addressed.
PARAMETERS OF THE DEBATE
Synthetic lubricants are fuel efficient, extended life lubricants manufactured from select basestocks and special purpose additives. In contrast to petroleum oils which are pumped from the earth and refined, synthetics are custom-designed in the laboratory, with each phase of their molecular construction programmed to produce, in effect, the ideal lubricant.
In responding to objections most commonly raised against synthetics it is important to establish the parameters of the debate. When speaking of synthetic motor oils, this article is defending the synthetic lubricants which have been formulated to meet the performance standards set by the American Petroleum Institute (API). (The first such synthetic motor oil to meet these industry-accepted tests for defining engine oil properties and performance characteristics was AMSOIL 100% Synthetic 10W-40 in 1972.)
Many people with questions about synthetics haven't known where to turn to get correct information. Is it super oil or snake oil? Some enthusiasts will swear that synthetics are capable of raising your specialty car from the dead. On the other hand, the next fellow asserts that synthetics will send your beloved car to an early grave. Where's the truth in all this?
In an effort to set the record straight, we've assembled ten of the more persistent myths about synthetic motor oils to see how they stack up against the facts.
Myth #1: Synthetic motor oils damage seals.
Untrue. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
Myth #2: Synthetics are too thin to stay in the engine.
Untrue. In order for a lubricant to be classified in any SAE grade (10W-30, 10W-40, etc) it has to meet certain guidelines with regard to viscosity ("thickness").
For example, it makes no difference whether it is 10W-40 petroleum or 10W-40 synthetic, at -25 degrees centigrade (-13F) and 100 degrees centigrade (212 degrees F) that oil has to maintain a standardized viscosity or it can't be rated a 10W-40.
Myth #3: Synthetics cause cars to use more oil.
Untrue. Synthetic motor oils are intended to use in mechanically sound engines, that is, engines that don't leak. In such engines oil consumption will actually be reduced. First, because of the lower volatility of synlubes. Second, because of the better sealing characteristics between piston rings and cylinder walls. And finally, because of the superior oxidation stability (i.e. resistance of synthetics against reacting with oxygen at high temperatures.)
Myth #4: Synthetic lubricants are not compatible with petroleum.
Untrue. The synthesized hydrocarbons, polyalphaolefins, diesters and other materials that form the base stocks of high quality name brand synthetics are fully compatible with petroleum oils. In the old days, some companies used untested ingredients that were not compatible, causing quality synlubes to suffer a bum rap. Fortunately, those days are long gone.
Compatibility is something to keep in mind, however, whether using petroleum oils or synthetics. It is usually best to use the same oil for topping off that you have been running in the engine. That is, it is preferable to not mix your oils, even if it is Valvoline or Quaker State you are using. The reason is this: the functions of additives blended for specific characteristics can be offset when oils with different additive packages are put together. For optimal performance, it is better to use the same oil throughout.
Myth#5: Synthetic lubricants are not readily available.
Untrue. This may have been the case two decades ago when AMSOIL and Mobil1 were the only real choices, but today nearly every major oil company has added a synthetic product to their lines. This in itself is a testament to the value synthetics offer. But, beware, many of the other "syntheitcs" are not true PAO (Polyalphaolefin) syntheitcs (ie: Castrol Syntec, Penzoil, etc...) they are hydroisomerized petroleum oil or an ester based synthetic blend.
Myth #6: Synthetic lubricants produce sludge
Untrue. In point of fact, synthetic motor oils are more sludge resistant than their petroleum counterparts, resisting the effects of high temperatures and oxidation. In the presence of high temperatures, two things happen. First, an oil's lighter ingredients boil off, making the oil thicker. Second, many of the complex chemicals found naturally in petroleum basestocks begin to react with each other, forming sludges, gums and varnishes. One result is a loss of fluidity at low temperatures, slowing the timely flow of oil to the engine for vital engine protection. Further negative effects of thickened oil include the restriction of oil flow to critical areas, greater wear and loss of fuel economy.
Because of their higher flash points, and their ability to withstand evaporation loss and oxidation, synthetics are much more resistant to sludge development.
Two other causes of sludge - ingested dirt and water dilution - can be a problem in any kind of oil, whether petroleum or synthetic. These are problems with the air filtration system and the cooling system resoectively, not the oil.
Myth #7: Synthetics can't be used with catalytic converters or oxygen sensors.
Untrue. There is no difference between synthetic and petroleum oils in regards to these components. Both synthetic and petroleum oils are similar compounds and neither si damaging to catalytic converters or oxygen sensors.
Myth #8: Synthetics void warranties.
Untrue. No major manufacturer of automobiles specifically bans the use of synthetic lubricants. In point of fact, increasing numbers of high performance cars are arriving on the showroom floors with synthetic motor oils as factory fill.
New vehicle warranties are based upon the use of oils meeting specific API Service Classifications (for example SG/CE). Synthetic lubricants which meet current API Service requirements are perfectly suited for use in any vehicle without affecting the validity of the new car warranty. In point of fact, in the over 25 years that AMSOIL Synthetic Lubricants have been used in extended service situations, over billions of miles of actual driving, these oils have not been faulted once for voiding an automaker's warranty.
Myth #9: Synthetics last forever.
Untrue. Although some experts feel that synthetic basestocks themselves can be used forever, it is well known that eventually the additives will falter and cause the oil to require changing. Moisture, fuel dilution and acids (the by-products of combustion) tend to use up additives in an oil, allowing degradation to occur.
However , by "topping off", additives can be replenished. Through good filtration and periodic oil analysis, synthetic motor oils protect an engine for lengths of time far beyond the capability of non-synthetics.
Myth #10: Synthetics are too expensive.
Untrue. Tests and experience have proven that synthetics can greatly extend drain intervals, provide better fuel economy, reduce engine wear and enable vehicles to operate with greater reliability. All these elements combine to make synthetic engine oils more economical that conventional non-synthetics.
In Europe, synthetics have enjoyed increasing acceptance as car buyers look first to performance and long term value rather than initial price. As more sophisticated technology places greater demands on today's motor oils, we will no doubt see an increasing re-evaluation of oil buying habits in this country as well.
CONCLUSIONS
Since their inception, manufacturers of synthetic motor oils have sought to educate the public about the facts regarding synthetics, and the need for consumers to make their lubrication purchasing decisions based on quality rather than price. As was the case with microwave ovens or electric lights, a highly technological improvement must often overcome a fair amount of public skepticism and consumer inertia before it is embraced by the general population.
But the word is getting out as a growing number of motorists worldwide experience the benefits of synthetic lubrication. The wave of the future, in auto lubes, is well under way.
Old Jun 10, 2004 | 09:41 PM
ramfan5.9's Avatar
ramfan5.9
aite thanx and one more quik question if u dont mind
if i wanted to use synthetic oil in a 97 dodge ram 1500 w/ the 5.9 ltr 360cid wut wud be the best to use
thanx for the help guys
Old Jun 11, 2004 | 02:49 PM
sgbofav's Avatar
sgbofav
DODGE TRUCKS RAM 1500 PICKUP 5.9L 8-cyl VIN Code Z
FILTERS
Oil Filter......SDF42 or (SDF-15 1.5"s longer, provided no clearance issues lengthwise)
Oil Vapor Filter......CB27
Air Filter......TS29
Fuel Filter......N/S
PCV Valve......HV113
Trans......TF42
BOSCH SPARK PLUGS
All submodels
Wire......B09789
Plug......B4418
BOSCH WIPER BLADES
Driver side......B40920
Passenger side......B40920
CHASSIS LUBRICATION
Four-wheel drive
5-11 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Two-wheel drive
6-9 Fittings, 0 Plugs..........LB
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 10W-30 Synthetic Motor Oil
SAE 10W-30 XL-7500 Synthetic Motor Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
Above 0°F......10W-30[1]
Below 32°F......5W-30
Manual Transmission,NV3500.....GLS[2]
SAE 5W-30 Synthetic Motor Oil
http://www.amsoil.com/products/hdd.htm
SAE 5W-30 XL-7500 Synthetic Motor Oil
Manual Transmission,NV4500.....GL-4
75W-85[3]
Series 2000 Synthetic Gear Lube
SAE 75W-90 Synthetic Gear Lube
Manual Transmission,AX-15.....GL-5
75W-90
Automatic Transmission.....AP4[4]
Synthetic Automatic Transmission Fluid
Standard Differential, Front Dana 44 & 60.....GL-5
80W-90
SAE 80W-90 Synthetic Gear Lube
Standard Differential, Rear Dana 60.....GL-5
90
Controlled Slip Differential, Rear Dana 60.....GL-5*[5]
90
Slip-Lock Differential Additive
Controlled Slip Differential, Rear Others.....GL-5*[6]
80W-90, 80W-140, 85W-140
Series 2000 Synthetic Gear Lube 75W-140
SAE 85W-140 Synthetic Gear Lube
Standard Differential, Rear Others.....GL-5[6]
80W-90, 75W-90, 80W-140
Transfer Case,.....AF3
Transfer Case,.....AP3
Fluids
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil Click here for more information
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
1. 10W-30 is preferred.
2. GLS is a special gear lube, Mopar part no. 04874464.
3. GL-4 synthetic gear oil, Mopar part no. 4874459
or Castrol Syntorq are recommended.
4. Daimler Chrysler Corp. recommends that all vehicles with
Chrysler automatic transmissions be serviced with ATF+4
Automatic Transmission Fluid.
5. W/ Cs, add 6.5% Mopar Trac-loc additive.
6. Dana rear axles w/ cs: Use 0.6 pints of additive in the 80.
All others use 0.4 of additive.
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........20.0 quarts
Automatic Transmission, Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
42RE..........11.0 quarts
46RE..........13.0 quarts
47RE..........17.0 quarts
Manual Transmission, AX-15..........6.5 pints
Manual Transmission, NV3500..........4.2 pints
Manual Transmission, NV4500..........8.0 pints
Differential, with Dana 44 Front..........6.8 pints
Differential, with Dana 60 Front..........7.6 pints
Differential, with 7.25 ring gear Front..........3.0 pints
Differential, 2WD with Dana 60 Rear..........6.3 pints
Differential, 4WD with Dana 60 Rear..........7.2 pints
Differential, with 7.25 ring gear Rear..........3.0 pints
Differential, with 8.25 ring gear Rear..........4.4 pints
Differential, with 9.25 ring gear Rear..........4.9 pints
Transfer Case,NP241..........5.7 pints
Transfer Case,NV241HD w/ PTO..........10.0 pints
Transfer Case,NP231, 233..........2.5 pints
Transfer Case,NP241HD..........6.5 pints
Transfer Case,NP241 W/ Dsl..........6.5 pints
1. After refill check oil level
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
TORQUES
Oil Drain Plug.....25 ft-lbs
Oil Drain Plug.....20 ft-lbs
Transfer case
Fill Plug.....30-40 ft-lbs
Drain Plug.....30-40 ft-lbs
Manual Transmission NV3500
Fill Plug.....14-20 ft-lbs
Drain Plug.....14-20 ft-lbs
Manual Transmission NV4500
Fill Plug.....25-35 ft-lbs
Drain Plug.....25-35 ft-lbs
Manual Transmission AX-15
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
Old Jun 11, 2004 | 08:35 PM
ramfan5.9's Avatar
ramfan5.9
aite thanx for the help guys this site kiks @$$
Old Jun 11, 2004 | 11:24 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
And in case you didn't catch on, they sell Amzoil. It's a good product, I use it along with Mobil 1. No problems with oil at all. Not a single drop has leaked. The only oil I've seen is in my oil catch can, and that's not the oil's fault....[&:]
Old Jun 12, 2004 | 04:16 AM
71RoadRunner's Avatar
71RoadRunner
That's right, it's a design flaw that wasn't fixed in the turbo cars 20 years ago, so why fix it now.[sm=smiley29.gif]
