MIL
Old Jul 17, 2006 | 03:16 AM
Phil03's Avatar
Phil03
Default MIL
mil just came on out of nowhere. i just bought the truck, 03 btw. what can i look at right off? stock exhaust except for dumped 3 chamber flowmater.
Old Jul 17, 2006 | 03:29 AM
dodgerules86's Avatar
dodgerules86
Default RE: MIL
I'm not for sure, but I believe you can turn the key on-off-on-off-on (thats 3 cycles, sometimes it takes 4 or 5 cycles, depending on the car I guess, "on" does NOT mean start). the odometer should give you a reading. Match what it says to codes given here.
Alternativly, you can take it to most many auto parts store, which can hook up their code reader for free.
Post back with results (the code you get).
Old Jul 17, 2006 | 03:32 AM
Phil03's Avatar
Phil03
Default RE: MIL
thanks for the reply, i'm renewing myself to the dodge family after being in the mustang hobby for a few years. any help is greatly appreciated.
Old Jul 17, 2006 | 03:40 AM
Phil03's Avatar
Phil03
Default RE: MIL
hmm, tried the on/off routine and nothing showed up
Old Jul 17, 2006 | 03:52 AM
dodgerules86
Default RE: MIL
Hmm.. tighten your gas cap! lol... seriously though, the MIL light can come on for a gas cap that is not on good enough (and sometimes people spend hundreds of dollars come to find out either their gas cap isn't on tight enough, or their $10 gas cap is "faulty")
But, of course, before you buy any part, go go Autozone or some place and get the codes read.
Old Jul 17, 2006 | 05:16 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: MIL
You're short one on/off there
Turn the ignition key until the digital odometer displays, repeat three times in succession and then back to "On" (On/Off, On/Off, On/Off, On). At the fourth "On" the odometer will be replaced with codes. If no codes are present then "Done" will appear.
If that doesn't work, head to Autozone and have your codes read for free
Old Jul 17, 2006 | 07:37 AM
dodgerules86
Default RE: MIL
Figures, I'm used to the old OBD systems, where you count the flashes.
Old Jul 17, 2006 | 09:18 PM
Phil03's Avatar
Phil03
Default RE: MIL
442, looks like i get to hunt down the hose and buy a new one.
